Plant ID request, and photos of May in Arkansas
MSCantrell
So I stopped to stretch my legs in a rural area this week, and I got out to see what was growing.
So I saw this guy, and it's familiar, but I can't place it. Help me out.
Here's where it was: down to the right. Rocky clay soil, partial shade.
Here's the specimen in question:
And a closeup:
So what is it? :) :confused:
On related notes, here's how the season is progressing this week. (This is my first year in Arkansas- moved down from Michigan, where the growing season is MUCH shorter. So this is really exciting.)
Blackberries have set fruit:
So have the grapes!
And here's something we've all read about, but I've never seen in real life: a swarm of honey bees. This is how they propagate- when certain conditions are met in an established hive (forgive me for not remembering what exactly... crowding? two queens?) a queen and a whole bunch of bees head out, find a spot, and build a new hive. Right now they're attached to the vinyl siding of a home.
Wild, huh?
Thanks fellas!
Ah ha!
Maybe that's why I couldn't remember- I was thinking edible, but it's a medicinal.
Thanks, Doc!
Ah ha!
Thanks, Doc!
You're welcome, MS, but not just a medicinal:
WARNINGS!:
- What can not be stressed enough, whether any part of mullein is to be used fresh or dried in an infusion, decoction, or oil, is the need for straining these liquids through a double layer of muslin in order to eliminate the fine hairs that cover all parts of the plant, including the flowers. These hairs can otherwise cause itching in the mouth even after they have been steeped in liquid. (JW222)
- Mullein seeds are toxic and may cause poisoning. (KV387)
TECHNOLOGICAL USES:
-leaves can be used as a pot holder (ASG9/00)
-nature's toilet paper (see rubefacient, below )
-an excellent pithy core, found in the stalk, was used as a charred tinder material. (KK36)
-the dried stalk was used as a hand drill for friction fire making. (TB7-147)
-large amounts of the fresh, crushed leaves and seeds (which contain greater volumes of rotenone) were used as a fish stunner. (ASG9/00)
- This use as a fish stunner can be traced back more than 2000 years. (JW220)
- dried flowerheads, soaked in tallow, produce marvelous torches. (TB7-147)
- the plant can be put to a variety of domestic uses, including a good lamp wick, a torch, if the whole plant is used, and as a glove for picking stinging nettles. (RM186)
- crushed up, dried leaf will serve as a fairly good tinder for firestarting.
- first stripped of leaves, then dipped in suet, pitch or resin and lighted, mullein stalks served as the candles and torches of ancient kings and commoners, alike. Until cotton came into common use, the down of the leaves served for tinder and lamp wicks because it ignited upon even the slightest spark. (JW219)
- wooly mullein leaves, slipped into shoes have warmed many a poorly shod foot throughout the ages, including in modern times of great need. (JW220)
- native Americans lined moccasins with the warm, wooly leaf. (JM31)
- if you boil down a large quantity of mullein plants in water and pour the decoction into fish ponds, the saponins in the mullein will reduce the surface tension of the water to such an extent that the water will get into the gills of the fish, which then drown in their own "element". (HP190)
GENERAL (includes legend and lore):
-it was brought to North America from Europe and was well established by the 1800's. (EJ239)
-ancient cultures around the world considered Mullein a magical protector against witchcraft and evil spirits. (KV385)
- common name, Mullein, comes from the Latin mollis, meaning soft. (BN-39)
- "The name, mullein, has 2 possible derivations - it come either from MOLLIS, which means 'soft' in Latin, or the Latin word, MULANDRUM, which comes from MELANDERS, and means 'leprosy' - an illness this plant was used to treat. 'Verbascum' means 'mullein' in Latin. It derives from the word 'BARBASCUM' which means "with beard". Roman men shaved, barbarians didn't and mullein is certainly as wooly as any barbarian you'll ever encounter. The species name is THAPSUS because mullein resembles the European genus, THAPSIA, named after an ancient town in present day Tunisia. (WM248)
- Mormon women, forbidden to use makeup, rubbed the rough leaves of this rubefacient (to cause reddening of the skin by means of counter-irritation (RM240) on their cheeks to create a beautiful red flush. People who spend time in the woods are attracted to mullein's large velvety leaves when they run out of toilet paper, again creating a beautiful red flush on their cheeks. (WM249)
- ADDITIONAL INFORMATION
· "Most rubefacients are quite irritating. It seems likely that it is the irritation of the tiny, woolen hairs of the Mullein leaf that causes the reddening." (SH230)
·Maybe only the 1st year leaves have rubefacient effect [see SH230].
·Rubefacient - An agent that reddens the skin by producing active or passive increases of blood to the skin. (HM17)
- Archaeologists sometimes look for Indian sites where there's lots of Mullein, because the lime from the Indian shell piles increases soil alkalinity, encouraging this plant to proliferate. (WM248)
- Mullein rosettes can be found in any month of the year. (CJ240)
- Like Evening Primrose and Queen Anne's Lace, Common Mullein is popularly called a biennial but may live for more than just 2 years. If the rosette of leaves grow fast the first year, then the plant will bloom the second year. If the rosette is still small after the first year, then it will grow for a second year and produce blooms the third year. (EJ241)
- The stalk can be 6 or more, feet tall and if you look at its lower part, you will see that it is clearly 5-sided. When the leaves are on the plant, you can see that they are arranged in a spiral up the stem, every 5th leaf directly above one below it. This same arrangement of leaves can be seen on Blackberry stems, which are also 5-sided. (EJ241)
- The flowers, when in bloom, seem to be scattered up and down the stalk, but there is order to this seeming randomness. They are arranged in several spirals up the stem and each flower in bloom is preceded by the one lower on the spiral and will be followed the next day by the one higher on the spiral. Each flower is open only one day, from dawn to midafternoon. (EJ243)
PERSONAL OBSERVATIONS:
- works as a hand drill, although not my favourite because of the careful cleaning of the stalk, required. If you don't clean it well, it chews the hell out of your hands.
- makes an excellent lamp wick
So you see, a very useful plant.
Doc
WOW.
My socks are knocked OFF.
Thanks a million for taking the time to put this information all together.
I've saved it to my repository for reference.
When I showed this to my wife, she said she had been thinking of growing some. Maybe I'll transplant a couple to the garden. :)
WOW.
You're quite welcome, but it represents copying from my plant notes rather than a new creation, so it wasn't a big deal.
Doc
