Plasti Dip
I was in Harbor Freight today and picked up an aerosol can of Plasti Dip -- the stuff you can spray on tool handles and other items in multiple coats to prevent corrosion and/or provide a good gripping surface. I'm almost finished with a 5" cleaver I'm making for a friend (my first try at knifemaking), and I'm thinking I could spray a light coat of Pam on the blade edge and then apply several coats of Plasti Dip about 1" wide to make an edge guard. Seems like a good idea both for safe delivery of the knife and for use as a storage guard. Anyone tried such a thing? Does it work as well as I think it might?
TIA.
Shalom,
Mark
I don't know about an edge guard, but for handle coatings it doesn't work for beans.
I won a knife at a show about 16 years ago. It had a drilled tang, and I guess was supposed to be a "tactical" knife, and the maker had dipped the tang in Plasti-Dip. It was real bad, and the coating was loose. I just cut the stuff off, and have never liked that makers products to this day.
For coatings, I would suggest truck bed coatings. They stick real good.
Dupli color makes it in a spray, and there is another company, Herculiner, that sells theirs in a one gallon can, for roll on application.
You can get either at Wal Mart, or many auto parts stores.
It comes in several colors also. :eek:
The Plasti-Dip reacts with many products, one being WD40. It will get gummy and tacky and make you nuts. I imagine most petro. products will react with it much the same way. I'm not very fond of it you might say.
Thanks for the feedback guys. Based on your responses I'll probably go ahead and try making the edge guard with it, but I won't be putting what's left over on the handles of some old pliers and Channel-Locks as I had planned to. I use WD-40 from time to time, and it's not unusual to have to wipe some of it off of my tools at the end of a job. If I decide to coat some of my tool handles I'll pick up the truck bed liner stuff.
Shalom,
Mark
