Plastic scales haze
LEGION 12
Hi everybody working on a old camillus slipjoint and i keep getting a white haze on the black plastic scales. Tried dish soap and water then mineral oil came back washed em again tried some flitz same thing . Anybody see this before. Thanks Rich
I've seen this on older delrin-handled knives. It's especially noticeable on older Case Sod Busters with the black delrin, which really shows the grey haze. If I recall, some older knives had delrin or similar handles which would haze over because of chemicals leeching out from the scales and oxidizing. I think the implication was, if a knife was new, especially, to make sure it was able to 'breathe' or air out, to allow the chemicals to evaporate off before the scales get oxidized. In a way, similar to the 'outgassing' of old celluloid-scaled knives, but not nearly as damaging or dangerous (or corrosive to any metals nearby). I don't think this is an issue with newer versions of delrin, as I've only seen it on older knives. Old knives that were in 'new old stock' condition, and still wrapped in factory packaging, I think were most vulnerable.
You might be able to use some very fine wet/dry sandpaper, or a Scotch-Brite pad, to sand/scrub off the haze. Or perhaps try some metal polish (with very fine abrasive) to remove it. (Edit: I see you've tried that already.) Whatever you try, just do a very small spot initially, to see if it looks like it'll work. Might even post a pic or two here of the knife, so we can get a better idea of what you're seeing.
I know I've seen a similar post from someone else here, a while back. I think I replied in that thread too, and if I can find it, there may be some more details as to what's going on. I'll link it here if I find it.
Here it is. This link goes directly to a post in an older thread, with a very detailed description and pics:
http://www.bladeforums.com/forums/s...-can-go-wrong-with-them?p=9988190#post9988190
Thanks Dave when i found this knife the haze was there thought i got rid of it . Put it away for awile when i pulled it out it was back . Scrubbed it again last night flitzed again then i put some more mineral oil stuck it in the sun for awile its 80* in chicago in march ! Whiped it down and so far no haze at all I was unaware of that problem with Derilin but makes sense to me . If it comes back il try lightly sanding it if that doesnt work just have to live with it. Working on posting pics my computer doesnt seem to want me to for some reason . Thanks again Rich
I would be curious to see some pics of this knife. If the haze is somehow due to the delrin being excessively dry or whatever, some more soak in mineral oil might help that. I've given a mineral oil 'soak' to some of my delrin-scaled knives, after cleaning them. I do this more to let the mineral oil penetrate into all the nooks & crannies of the knife, which helps protect against rust (I do this more with non-stainless knives). Nice thing about delrin is, you can leave the knife immersed in it for days at a time, or longer. I left one of mine immersed for weeks; basically forgot about it, with no adverse effects after I finally took it out again. The mineral oil certainly won't harm it, and it might be somewhat rejuvenated by it (just maybe). I'd avoid solvents like alcohol, acetone or mineral spirits; they might dry out the delrin even more.
Would like to post pics actully have been trying since i joined this site but for some reason the computer i have doesnt let me i even have a photobucket account to be honest havent had the time to fix it . If you would like pm me your email and when i get home il send some to you i have no problem doing that . Rich
