This is what I do and it works pretty well for me.
I use 3x1x12 aluminum stock as quenching plates.
Finish to 600 grit and double foil wrap, put in oven while it's cold, spine down, tang towards door.
Ramp to 1200 hold for 5-10 min., ramp to 1500 hold for 5-10 min., ramp to 1775 hold for 20-25 min.
I clamp the bottom plate hanging over the edge of the table right next to my oven, as soon as the oven has done its thing I put on welding gloves grab some pliers and take the knife out quickly but carefully, so as not to bump it into anything, place it spine down on the bottom plate turn it onto its side and quickly sandwich it between the top and bottom plates. I hold it with a spring clamp for about a minute.
Then cut open the foil, check for warp, test hardness and temper immediately.
When I dry ice treat them, if I remember correctly, 450 degree double temper gave me 60 HRC. And without dry ice I think I got 59 HRC with a 400 degree double temper.
