- Jan 25, 2006
Hi,
I use a 2x42 grinder, the older 3 wheel model. The platen is a piece of bent 1/8 steel, approx 5-6" in height. I would like to make a longer platen so i can more easily put a longitudinal brushed finish on my knives (before finishing them by handrubbing). I plan to make a longer one by bending or welding so i have a 2 inch by 10" platen, and a 2x3" tab at the bottom by which it is mounted onto the grinder body. Alternatively I could get a heavy corner brace or piece of heavy angle 2" wide and bolt the platen to it.
The problem is I need to prevent the top of the platen being pushed back from the belt by the pressure of grinding. This already happens to some degree with the current platen, it will be at least twice as bad with the longer platen. The top tracking wheel also moves in an arc to provide tension, so there must be some control over the the position of the top point. The bottom point is varied using a bolt and slot.
I would like to use one or two bolts or pushers to provide support for the top edge of the platen.
I could glue a piece of wood or metal to the body just below the contact wheel so that bolts could be fed through and push on the top backside of the platen.
Or I could those things that have two threaded parts and a tube, such that when the tube is turned both bolts either extend or retract but I am not sure what they are called. Can anyone help me with the name? It is the kind of the opposite of a threaded tensioner for wire. Ideally they have free turning ball and socket plates so i can glue the plates onto the rear of the platen and the grinder body and then twist the tube to vary the amount the top of the platen is pushed out towards the belt.
Does anyone have any thoughts or suggestions?
