I broke off the rectangular piece of steel seen on the far side of the the air duct in this picture. I assume the material is some sort of austentic stainless steel. The grain structure appears to be visible. I pounded it flat against a 2x4 and sharpened some of the edge on a medium and coarse combination stone. So I ended up with a 7 x 1 inch piece of metal 0.4- 0.5 mm thick with about 3 inches of edge.
The edge it was able to obtain was reasonable, a little worse than my Jaguar POS seen in the first picture. It can for instance with some effort cut a roll of newspaper under its own rigidity. I tried opening a food can. The inital entry was done with the square corner of the tip, and the first cut was reasonable. The edge was basically ruined, however. You can at this point rip it out of someone's grip and not be cut. I tried to make the cross cut but the corner folded before it penetrated the can. I finished up the job with my beat up Jag using it like a locking folder (the lock has been previously compromised). I sharpened the knife back up to its previous sharpness. It could make some rough shaving from a softwood 2x4. I actually like it better than the Jag for this duty as this piece is long enough to use it like a draw/push-knife with both hands.
I tried some batoning with it. It is able to split 1 3/4 inch thick wood, something the 1 4/5 inch long Jag is not able to do. However the piece of steel basically took on the shape of the wood. In order to sharpen it again you would have to flatten the knife out again. The first split was a nice wedge shape though. With the Jag I shaped the point a bit and using the Jag to start a cut and using the wedge to continue it split 3 other pieces off. The rest were really knotty and unworkable.
I compared carving the wedge between the Jag (this time roughly free sharpened on a coarse/medium stone, 15/20 with heavy deburring) and a Military (12 degree edge, 15 micro + deburring, sharpened on Sharpmaker a while ago). The Jag could handle strong pushes from the arm (something Cliff doubts his POS folder can do), but the blade length, sharpness, and edge configuration compared the Military made it seem about 4 or 5 times less productive in removing material.
