Playing Both My 16 Tweeners (shorts).....
I would like to start this thread off with a big thank you to Ka-bar, Ethan, the Mods, and bladeforums for me winning my BK-16 last month. The generosity around here is overwhelming at times. Thank you.
On to the knives! Well I picked a FPR 16 when they first came out and loved it then I won an awesome FFG 16 so I thought why not take them both out to play together. This is not so much a head to head comparison as it just some observations.
Normal production BK-16
First observation of the BK-16 is the coating on the new blades looks and feels awesome and incredibly durable. The laser etching looks crisp and clean. A very sharp looking knife (pun intended ;) )
My FPR BK-16
Since getting my FPR 16 I have really enjoyed it. So far I have stripped the coating off, convexed the edge, and dyed the sheath and scales.
So First things first I started with battoning some small logs.
After that a little stropping was needed then they were both ready to play some more.
mmmmm Knife porn................... Back on topic
Next I decided to take a walk back to the deer blind on the back of the property.
On the walk there I came across a few wild strawberries, man were they delicious. I spent a good 30 min looking for more but the search was fruitless.
When I got there I noticed that some shoots were sprouting off of the tree I cut down last year so I decided to put the 16's t work. Both of them performed very well for this light chopping task.
Next I saw some grape vines that were choking up the tree next to the blind. Not sure if any of you guys have to deal with stuff on your property but they are a pain in the ass and near impossible to kill. I took turns using the 16's to do some chopping on the vines.
On the walk back to the house I came across what I was always told was wild carrots. Any of you guys know if this is accurate. Smells exactly like one but I wasn't about to eat it without doing some research.
I cut a small stick to dig it up with. Have a look.
Overview
I was really impressed with both knives. The FPR definitely seems more beefy and the normal production run 16 seems more nimble and agile in the hand. When battoning I found almost no difference in performance between the two. The normal production 16 seemed to stick a little more but I think it may have been due to the coating and not necessarily the grind. The only real difference I found was when doing light chopping (I know its not a chopper but if one needs to call upon it to do so)
The FPR 16 seemed to be better chopper due to being more forward weighted and lack of coating.
Bottom line
I would absolutely not feel undermanned with either knife in the woods. I think I might make the normal production 16 my designated hunting knife and use the FPR for more fun bush craft stuff.
Thanks for looking guys. Let me know what you think or any thoughts you have.
-Nathan (Nsvens89)
Great review and nice pictures!
I don't think you mentioned this, but how did the FPR compare to the regular production BK16 when batoning?
What color dye did you use for the sheath, and how long did you soak it?
Thanks,
-orangish ducktape
From your pictures, it does look like wild carrot. But still, do your research. Poison Hemlock has similar shaped leaves, growth pattern, and life cycle. Wild carrot will have hairs on the stem. A smooth stem with purple spots is poison hemlock and should not be eaten.
Great pics and review.... I really like the side by side shots and haven't seen them together before. Seems like the ffg would go through alot easier if it was stripped too.
Eli
That new coating is very frictiony (is that a word?) so it will slide thru media better stripped. my .02 cents
It does look better and holds up quite a bit better then the old style tho, and is way harder to strip off!
Nice pics, I like that deer blind. thanks for sharing your day.
Thanks,
-orangish ducktape
I think the FPR had the advantage but I think it was more so due to the lack of any aggressive coating like the normal 16 has. For it to be a fair head to head challenge the normal 16 would need to be stripped. (might do that at some point)
As far as the dye I used the liquid RIT dark brown and cooked in pot on low to med heat for about two hours. The scales were in the dye maybe 30 min and came out way too dark. It seemed like they went from being not dark at all to being too dark very quickly so if you try them keep an eye on them.
I think Mistwalker had a post recently where he detailed the "wild carrot" you have there. Gimme a sec and I will edit this with a link once I find it.
Hmmm, his looks different. Good call on doing research.
http://www.bladeforums.com/forums/showthread.php/957148-Some-Wild-Edibles-Stuff
Also congrats on the 16, it is a beaut of a knife!
Thanks for pointing me in the direction of miswalkers post I don't know how I missed that one. It was nicely done. I am pretty sure it is the same thing he had but next time out I'll bring one of the plants home to inspect it and compare it to the pictures and thanks I am definitely enjoying Ethans creations they both indeed beauts.
Yikes thanks for the info I had no idea that poison hemlock was so similar. I'll have to keep an eye out and see if I can find some for comparison.
Eli
Thanks Eli, I am sure the ffg would too. My dilemma is that I like the look and durability of the new coating but am not a fan of how much drag it causes and how much junk it collects. I am on the fence about stripping the ffg 16.
Hell if I understand what you are trying to say it's a word as far as I'm concerned. Me and my father built the blind just before the start of last bow season. I didn't get to hunt it much but it was definitely comfortable. I think my dad might throw a roof on it also. I think he is getting soft in his old age.
