Hi fellas, I could use some help here so I don't screw up my new Busse HR! I was checking a few sites on how to sharpen convex grind and basically it seems you draw the entire bevel over the strop lightly pressing the whole blade surface into the strop... as in this one from swiss army knives
http://www.mhcable.com/~yocraft/sosak/convex.htm
But on a Busse knife with a finish on it this will certainly wear off the finish over the whole blade surface (which might look even weirder on an HR with the corrugations)! I've read up other sites about acheiving the right angle (which is what I've always been concerned w/in the past, though I've often messed this up as well!) but on a convex grind you don't want to put an angle on it? This website discusses angling the blade, which sounds good, but maybe is a bad idea on a convex grind?
http://ludlowsurvivors.co.uk/viewtopic.php?t=108
So basically, on a Busse, you wear down the whole bevel or do you angle the blade? I'm sorry if I sound like an idiot! Thanks again.
Mike
Mike
