Hello,
I just recently purchased the original swisstool from Amazon.com, but the first one they sent me had a damaged pouch. I asked for a replacement which they sent expedited, so I have two swisstools in my possession right now (for a short time).
What I noticed is that the replacement swisstool has what appears to be the spirit's pliers.
-The spirit's pliers are wider at the base (pivot) at 2.5cm versus the swisstool's 2cm plier base.
-The spirit's pliers have an area for cutting hard wire indicated by a raised point in the cutting surface followed by a notch adjacent to the pivot; the swisstool merely has a notch in the cutting surface.
-The spirit's pliers have a smaller coarse plier grip area.
-The spirit pliers open only 3cm whereas the original swisstool pliers open 3.8cm measured from tip-to-tip on the inside. As a result, the spirit pliers are limited to grasping smaller objects than the original swisstool.
Given the differences in the pliers between the two, it would be my uninformed opinion that the original swisstool's pliers are more versatile than the spirit's pliers. Is this assessment correct? I have to return one of them back to Amazon.com - if you were me, which would you keep?
Thank you for your opinions and advice.
