I am trying to figure out what would be the ideal knife to attach to the tow post of our RHIB.
The primary use is to cut a 1" polypro tow rope in situations gone bad. Edge holding isn't too great an issue as it shouldn't see much use.
It will be exposed to frequent salt water baths with little care. Once a week it may get wiped down with Corrosion-X but that will realistically be the extent of the upkeep.
Ideally it will be single edged, at least partially serrated, blunt tipped so it doesn't puncture the tubes when dropped. Corrosion resistance should be good. It needs to be able to slice the rope in a single cut so I'm thinking min. four inch blade. Of course, cheaper is better as we are a volunteer organization. Sheath must be plastic or Kydex type.
What is out there that meets these requirements?
Thanks in advance
Jenks
Thanks in advance
Jenks
