Plumb axe with pointed lug
I found a Plumb axe today at a local junk dealer. I am hesitant to spend any money on it because, I just don't need a cutting axe. However I am trying to get some idea what I was looking at for future reference, I may possibly give in and go back for it if I believe it is pre ww2 cus I am a sucker for old.
I have been scrolling through pictures trying to get some guess, one detail is throwing me off. It is a single bit axe with a lug. The lug comes to a relatively sharp point. All of the Plumb axes I can find seem to have rounded points on the lug. Can anyone help me to reconcile this?
Other details that may help. I did not notice the shape of the bottom of the beard as it moves toward the lug, I know this detail helps to identify Virginia vs rockaway vs some other patterns. The handle has a red finish on it. The wedge is a traditional flat wedge (makes the axe post early 40s I believe). The plumb logo is in a box and located at the back of the head near the butt I did not notice any lettering under the logo, but the head is somewhat rusted, not heavily pitted though. I noticed clean areas in the cheek in the shape of a "raised wedge" I do not know the term for the shape. I have seen many older axes with raised cheeks, this is usually pronounced. On the axe I looked at a wear pattern existed in the same shape as these raised cheeks but any swell was insignificant. I now wonder if the axe had a relatively flat profile moving toward the butt rather than being raised except with "scoops" formed above and below the center line of the axe creating the same pattern without the swell.
I have looked at a number of examples of Virginia and Rocker style heads, all seemed to have the Plumb stamp on the cheeks in front of the eye rather than behind it as in this example.
If I decide to go back and look at this axe again is there anything specific I should look for?
Thanks in advance.
Yes, there is. You should go back with enough money to buy the axe, and then post some pictures of it. That will get you more responses and useful information on this subforum than any amount of description.
If you don’t need an axe, then you just don’t need one, nothing wrong with that. Your needs are what they are. Looks to me like you WANT one, though…
And welcome to BF-ATH, by the way.
Parker
Sounds like an older Plumb Jersey pattern, that wedge shape you're describing would be where the " phantom bevels " are.
At the top and bottom the cheeks are
recessed so there's less surface area to contact and stick.
I stopped back in today and had a closer look armed with a better understanding. I was able to reconcile my issues. The axe had been modified by a previous owner obscuring some details. The lug had been re shaped to a sharp V and the raised cheeks had been ground flat. Some black paint was left in the scallops which is why I could see the shadow of the raised cheek but it was so faint. Being as my only current need for a cutting axe is to have a nostalgic old tool to look at and enjoy I went ahead and left it there until I stumble on one in more original condition.
I did score a nice lakeside (Montgomery-Wards) tenon saw that I will get a little more use out of.
Thanks for your help
