Plumbers or anybody who knows ?
LEGION 12
Hi everybody i have a Delta Shower Faucet every couple of months it starts to drip so i replace the Seats and Springs a month or 2 later same problem is there anything i can do to permanently fix this problem dont think i need to replace the cartridge if i grease the Seats would that help ? Also should i lightly sand were the Seats sit LOL . Thanks in advance for any advice . Rich
Delta taps are usually guaranteed for life, so take the cartridge into any Delta dealer and they should just hand you a new cartridge free of charge.
Cartridge was just recently replaced did not stop the problem .
I found that the cheaper knock off cartridges don't last very long.
When I went with the Delta brand it never dripped again.
I had the same problem and it turned out to be some crap in the line was scratching the ball that ate the seats. With the ball and seats out run the water to flush the lines. Pile some towels around the base to soak up the water. It doesn't take long to flush them. The guy that told me about this said he had a needle in the line and the water pressure would push it up and sink back down when he shut the water off. I just had a little grit.
Thats exactly what i was thinking something has to be wearing them down didnt think to flush the lines thats gonna be a neat trick i am on the 2nd floor valve is in the basement guess i will have to do some running think i will take a emery board to the brass first in case theres something there . Thanks
is the rubber wearing, or is it breaking down? I've seen sometimes where the water dissolves the rubber, but not that fast.
There wearing out there still in one piece when i pull them i have to say the building i live in is very old so something hitting them from inside makes the most sense.
Most of the parts involving water are either brass or teflon with rubber or teflon o-rings. Both of which are soft materials and will eventually wear down to the point of leaking. Preventative maintenance is really the only thing you can do...replacing o-rings and cleaning/polishing parts. Wear time is also determined by your water type. If you have good clean water your, wear time is extended. If you have fair or poorly cleaned water and debris is commonly found, your wear time is dramatically cut down. These are soft materials your dealing with so its always going to be a bit challenging at times to keep them in good working order. You cant really grease anything because the water will wash it off, so water is basically your only lubricant...which its a very poor one. Quality of product and warranty will help alleviate some of your headache. Its just a part of being a good home owner to keep up with your appliances.
One ting I hear a lot is "...it never sue to do that before with my old system...". Well, its been proven that todays products are (for all intents and purposes) crap. Things aren't built like they use to be. Delta is a good brand name but just look at what they are built with and what your asking it to do. The older setups where changed for there reasons (probability for safety and efficiency reasons) and the older models most likely had years of crud and water junk built up top prevent leads from occurring. It doesn't mean you have a bad system just because it leaks consistently, but apply common sense and see if its worth your time and money. Consistency wear and tear is not necessarily a bad thing, it can be annoying at times though.
Well i replaced the seats and springs after i flushed the lines no leaks will see how long it lasts. Thanks for all the advice
