Plunge line jig
This is actually on a great thread on the knife forum. I couldn't figure out how to bring the entire thread here, so here's just my part. This is a jig for doing the plunge cut. I know, it's not for everyone, most prefer to use the traditional methods, and I do that also. However, I just tried this today, and got great results, so all I'm doing here is passing on the info on the jig I made. For more info, check out the other thread on the knifeforum.
This is the jig I made. It's just a block of wood, cut at an angle, with a piece of micarta epoxied to the block. The wood is lag bolted to the "small wheel attachment" of my KMG. Note that the edge of the micarta does not extend quite to the roller, this makes it easier on the belt, as it takes a beating being used this way. Also note that the micarta is angled so that when the blade is placed on it, the tip (which would be away from you) would be hanging out in the air, above the belt (hope that makes a little sense). The other photo is of a D2 blade that's been heat treated (Thanks Roger), and then the plunge was cut in. Next time I'll do most of the plunge first, then heat treat, then plunge some more.
NOTE: This is NOT my idea, it belongs to the guys that wrote the original thread on the other forum. Ron Claiborn (Bowie) was very instrumental in the design. What you see here is just my take on the whole thing. It works very well, but because you can't see the actual plunge line being cut by the belt, you have to learn to "feel" where the plunge actually is. It takes a little practice believe me. To make the plunge, you place the blade on the belt (in line with it), with the tip towards the machine, and the handle towards you. A little before where you want to end up at, you start making the plunge cut, first one side, then the other. As you develope the groove, you can start working on making each side even with the other. The blade in the picture was hand sanded with 600 after the plunge cut (the belt was 220, then 400).
Cool theory of operation. I like that idea. Never would have thunk of that. That is a KMG isn't it? Don't recon I'll try that on my Coote.
RL
Very nice. Just currious. Were you having trouble with the "standard" way of doing the plunge cuts? The think I like about it is that it will lessen the 2" grouve issue....
Thanks Robert --- But i feel i need to set the record straight i had a part n the thread on the other forum and i was lucky enough to be told to do this but ( I had Nothing to do with the design ) Boy Do wish I did would have saved me hours of work this was told to me by Jerry Van Eizenga of Michigan while he was here to demonstrate .at this years Hammer -in , it was told to him by another person that he cant recall
1. One was built for me by Larry Kemp.
2. it’s a good read and thanks Robert For passing it on
Boy I wish I had this long ago
My Name is Ron Claiborne ,im a knifemaker and im 1day Damascus free
Blgoode said: "Were you having trouble with the "standard" way of doing the plunge cuts? "
No, I can do a plunge that suits me ok. (having said that, I don't know that I've ever done a plunge that I was absolutely 100% happy with). This sure saved a lot of time for me though. It's not for everyone, it's simply an idea, to make the plunge cut, that's all. It does seem to work well for me however. I prefer the J-flex belts for this. The thicker grits don't travel over the edge so well, the the "J"'s do so very well (yellow 220 and finer). Today I'm adding a ceramic platen to my KMG plunge outfit, to lessen the belt fricton.
Thanks Ron for clearing up the designer issues! I'm betting that you'll fall off the wagon by the end of the weekend though.
looks like a great idea...I'll have to give it a shot...I have the small wheel attachment just like yours.
This is something I will just HAVE to try. It will be a bit more of challenge with my Hard Core small wheel attachement. I may be able to use the flat platen setup instead. Will have to do some "engineering".
News at 11...
Craig
