I used a plastic pry bar and worked it down one side between the G10 and the metal, then the other. Repeat. Eventually there was enough clearance to twist them apart.
The lanyard tube is pressed/flared at the ends. Pull harder.
I've heard sticking the handles in the freezer helps since it makes the metal contract just enough that you can pry the lanyard tube out of its grooves. Never done it myself but the questions come up before and I've seen others speak highly of it
thanks for the help guys..finally managed it by slowly prying the liners of out from under the scales until the lanyard tube gave way, so am enjoying my new scales now![]()
Pics or it didn't happen...
