Why polish the edge if you are going to microbevel with a 1k stone?
Why not? Because you are using a larger abrasive than primary bevel was sharpened with. The larger abrasive being used on the microbevel does not allow it to be a microbevel because you at not decreasing the size of the primary edge apex. You would be better off just using a coarse stone.
A bevel that small does not produce enough drag, the thickness behind the bevel, the shoulder of the bevel, and the type of grind the blade itself has are the drag in cutting, not the bevel.
If you really want to reduce drag then polished is not the way to go. It promotes stiction when cutting.
