A PM2 with S90V ? From where ?
And S90V is outstanding in edge retention. But if you're having to sharpen S30V (which is a great steel) all throughout the day then you must be doing some severe cutting at work.
I'm a fan of s90v, I have a seconds manix2xl that's my primary user in s90v and a sourhfork and they're my favorite so far. Great edge retention and no problems chipping so far. Para 2 is one of my favorite models and will be awesome in that steel.
Any of the steels will chip out on wire at some point of thinness or low angle. Less tough steels require more steel to support which makes cutting more difficult. I'd suggest a higher strength steel like 3V for what you do instead of a higher carbide steel that will probably wear the same way your current knife is.
It's all a trade off but for cutting wires the knife isn't the best tool requiring a trade off of thicker geometry and less cutting ease which essentially means duller blade.
If you can't carry a wire cutter maybe try something like the Tuff in 3V, or other similar higher strength instead or higher wear resistance steel as a test to see if that works better. Even going to something like Aus 8 or 6, or 440A, Bucks 420HC might show if you are losing cutting to wear or fracture of the edge.
Just a thought.
I do have wire strippers that work way better. But sometimes their on the other side of the unit haha. But I will try the m4 steel also.
It's my grail knife. I love S90V but you really don't want to let it get too dull, I learned the hard way. Now I touch mine up often so it doesn't get to that point.
If you got that CF/S90V pm2 in the classified here yesterday, it looks like you paid $250? If so, you basically stole that thing! I've been looking for one under $350-$400 with no luck. They all seem $500+...
it won't won't be as desirable when I'm done with it.It's my grail knife. I love S90V but you really don't want to let it get too dull, I learned the hard way. Now I touch mine up often so it doesn't get to that point.
If you decide to use it, let us know how it holds up to the wire.
'sal
You know you saying that means I have to use it now.
I would skip ZDP-189 for wires. Tuff in 3V, Gayle Bradley in M4, or Military or Manix in CRUWEAR would be one of mine I would pick.
