Wowbagger
- Sep 20, 2015
A heads up.
On my latest Spyderco, a stellar Para 2, blurple with S110V, I was going to move the pocket clip to tip up. I know . . . pure madness. Mostly I prefer the Para 2 with the clip removed but lately I had been EDCing my all black DLC with the clip in tip up mode to get it out of the way of my fingers near the pivot and found it a winner so I wanted to run my new 110V that way.
First I just carried it in the factory configuration. The clip was a little bit tight so I used the method of hook a paracord loop on the clip and gentley (very gently/I did not over do it) pull out on the clip to bend the clip out a little. Granted it was tough to bend.
What I found next day when I went to move the clip to tip up was the screws looked like they had clear thread locker on them. Under magnification I discovered the threads were bent over and distorted (practically stripped). I was in a bit of a hurry so I threaded them in and tightened them good and snug but less than I normally would.
When I got home from work that eve I notice the pocket clip had side to side play (moving back and forth like a sick clock hand). First time I have ever experienced that in a pocket clip.
I started looking close at the situation and found the length of the clip screws to be significantly too short. They do not penetrate all the way through the steel liners. This boils down to only two or less full threads engaging the liners. Correct me if I am wrong but I recall the engineering standard for minimum thread engagement should be five threads. Hard to achieve on a knife with sheet metal liners. Robust and perfectly wonderful steel liners. The liners are just fine. Still lets not push it guys by not engaging ALL of the liner thickness.
Yes I realize :
I don't have a good solution, I'm just saying don't use the paracord pull method on this knife.
PS: . . . come to think of it I do have a solution. Possibly not too problematic for all concerned :
Longer screws and washers under the heads of the longer screws to limit penetration past inside of liner surface.
Me . . . I will cut down some longer screws (I already have some installed that are too long except the one that would hit the blade).
Tip for do it yourselfers : the pliers in the SAK Mechanic are perfect for gripping the screws to grind or saw them down.
Yes I realize :
- fasteners only come in stock lengths
- cutting longer fasteners down to a custom length is not a cost effective option.
- some knife reviewers go bull shit if they see a thread or two protruding on the inside of a knife.
