Pocket clip for a Sebenza 25
Hello members.
Last week I ordered a pocket clip for my 25 . It arrived Saturday morning , and I couldn't wait to get it screwed in . I haven't been carrying my 25 since I snaged the clip on a seatbelt . Took the old one off and the new one didn't fit . It's too wide to fit it the slot .
Have any of you experienced this ? Is this normal? I'm sure a little filing and it will fit . Just want to ask you guys before I called CRK .
Thanks
They can be a pretty tight fit sometimes. I usually put the screw through the hole in the clip and tighten it down slowly and it will seat itself. If it is visually to large then something is wrong with it, be sure to let CRK know.
atony ,
I tried that a couple times . It just will go in . I will give it one more go and then call Angela .
Thank you
Did you just push the clip into down, because it's supoosed to slide into the slot from the recess instead. You have to put it into the recess in front of of the slot for the clip, and slide it into the slot while you wiggle it a little sometimes if its tight, then put the screw in last once its in the right place.
