Pocket clip for mini adamas
Phisig
I recenlty purchased a mini adamas from a BF member and replaced the scales with some custom scales. I've been looking for a custom pocket clip but there aren't many options. A lot of the options will fit a variety of other benchmade knives including mini versions. What pocket clips from other benchmade knives will fit the mini adamas?
Thanks,
Marc
I’m pretty sure the Mini Adamas uses the same standard Benchmade three hole pattern as most other Benchmades and Emerson knives. There should be lots of options out there in this hole pattern, if the replacement scales you got follow the same hole pattern, anyway.
The scales do follow the same hole pattern. I just wasn't sure if other clips would fit. I looked at other custom clips and they would list numerous benchmades but not the mini adamas.
I understand. There are very few models that don’t work with the standard Benchmade three hole pattern. The Mini-Adamas is a fairly new model, so searching for that model specifically might get you less results. I have a Mini Adamas and the standard carry OEM Benchmade clips have worked just fine, which lead me to believe the hole pattern is their usual.
I hear yah. I'm going to take a shot and order one. If it doesn't fit for some reasonz I'll put it on ine of my othet benchmade knives.
