- Nov 11, 2002
Hi -
Doing a forum search to find what I needed, I've seen other posts from members who've done the same as me. Stripped out the hole on the pocket clip screw. Like others, I used a dremel to cut a flat head slot and got it out. It wasn't even that tight but the CRK allen wrench didn't fit well enough. I need to pick up a good set with bits & a handle.
Anyway - I'd like to know the size of the screws and a potential source to obtain a couple spares. I'm sure I could get them from CRK, I'm just curious to see what else may be available. That high domed screw seems susceptible to stripping to me. Maybe use another screw that is a bit flatter and maybe torx. As an aside, I'm actually a bit surprised CRK hasn't gone to torx. Perhaps, out in the field, an allen set is easier to obtain and strip down your knife if needs be maybe. Dunno.
