I have both a common red laser, and one of the new green lasers. The green lasers are fantastically more powerful than the red ones. The green point is visible much further--more than three miles. Also, unlike the red lasers, the green ones cast a visible beam.
I recently tested a green laser against a signal mirror. The signal mirror was far brighter and more visible. A green laser should definitely not be your primary visual signaling device. However, as a back-up signaling device, it has several interesting features. Firstly, since the beam is visible, you can follow it back to the person with the laser, and pinpoint exactly where the person is. Being able to do this with a three+ mile range (at night) could be quite a good signaling aid. Secondly, the diffisuion of light reflecting off the spot where the laser is pointed is quite bright. (For example, I can light up my brother's windowless bathroom with it.) Thus, it can be used in a pinch as a weak flashlight, but with the odd advantage that you can also light up an area far away from you, instead of just right next to you.
SgtMike88 said:
"I cannot think of one, single good use for those dam* things outside of a classroom."
Here are four: 1) They are a dream come true for nature photographers, allowing us to cast a spot on a medium distant object in the dark, to focus properly for long exposures when light is insufficient for normal focussing; 2) They make fantastic cat toys--my cat never got tired of chasing the red dot; 3) they are great for sketching out a possible climbing route right on the rock face, and discussing it with a climbing partner; 4) they make it possible to point out a particular star, planet, constellation, satellite, etc. to discuss or teach astronomical stuff.
By the way, Mike, I disagree that they should be outlawed. If there must be yet another in the endless assortment of laws for every possible situation, it would be much less of an unnecessary infringement on people's liberty to outlaw reckless misuse of laser pointers than to comprehensively outlaw an item with plenty of legitimate uses. I should be able to carry and do any damn thing I please as long as I am not harming anyone.
Also, Mike, I think you need to come to grips with the fact that, outside of a combat situation, you are far more likely to encounter a child innocently fooling around with a laser pointer than a sniper. You would do better to retrain your reflexes for your civilian situations than to demand that the world must adapt to your views and ways.
