- Oct 2, 2014
Born from key influences in Dietmar Pohl's lifelong passion for knives, the Prepper One combines the hollow handle survival knife concept with a traditional style 'straight' utility knife. By using modern materials and manufacturing techniques, Dietmar Pohl has avoided all the typical weaknesses of hollow handle knives and produced a super strong design that won't let you down. This review features the Prepper One Tactical (G10 and wood handle), but the range also includes the Prepper One Survival, and Prepper One Outdoor (plus wood handle options for these).
Author's Statement for Transparency and Disclosure
The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons.
All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly.
The Blade and Handle Geometry:
Most knife specifications have a basic description of the blade geometry, but in this section I will be taking a more detailed look at geometry and balance.
Using a set of gauges and precision measuring equipment including a Vernier protractor, callipers, fixed radius gauges and the unique Arc Master adjustable radius gauge (the one that looks like a crossbow).
These measurements have been tabulated and are presented along with a few reference blades (8" Chef's Knife, 5.5" Santoku and the popular Fällkniven F1).
Key aspects such as the primary bevel angle, grind type, blade depth, blade thickness, length, weight are detailed, along with balance information.
The 'Balance relative to the front of the handle' tells you if the knife will feel front heavy, or if the weight is in your hand (a positive value means the weight is forward of the front of the handle). The 'Balance relative to the centre of the handle' indicates how close to a 'neutral balance' the knife has in the hand.
In the case of full convex grinds the approximate centre of the grind is used for the primary bevel angle estimate.
(Wherever you see the 'Read MORE' marker, it indicates that the Extended Version of the review has additional content at that point. Viewing the extended version helps support further reviews, but please ensure you return to this Forum for comments and discussion.)
The blade is made from Niolox steel.
New for 2018! BESS Certified sharpness testing:
The BESS 'C' scale of sharpness, developed by Mike Brubacher (Brubacher Edge Sharpness Scale) will now become part of Tactical Reviews' knife testing process. Initially this will be used to verify the sharpness of the factory edge and allow the knife to be brought to a minimum standard sharpness before testing a blade's cutting performance.
The Prepper One's factory edge has an average BESS 'C' sharpness of 345. At this sharpness it easily and cleanly slices 80gsm copier paper. It doesn't quite want to catch a rolled edge of the same paper, but will 50% of the time.
Explained by the Maker:
The reasons for certain design choices may not be clear when simply looking at an object, so this section is intended to give an insight into the thinking behind a design by speaking to the designer themselves.
Dietmar was kind enough to give me some time during IWA 2018 to discuss the Prepper One and where it came from.
Video Edited with - Cyberlink Director Suite 5 (PowerDirector 16 and AudioDirector 7)
Camera - Panasonic HC-V770 - Microphone - Tonor TN120308BL
A few more details:
The Prepper One Tactical arrived in a cardboard box.
Inside, the Prepper One was wrapped in paper (so much better than plastic).
In this case the wooden handles have also been included, but these are an optional extra. There was also a Pohl Force Patch and a certificate card.
Whipping off the paper wrap, the Prepper One arrives in its Kydex Sheath.
Let's start off with a look round the sheath. The belt loop looks like normal nylon webbing, however, the loop is actually very stiff and holds its shape.
The Kydex lips have been shaped and finished well, so unlike many Kydex sheaths there is no additional finishing required to ensure a smooth operation.
That stiff webbing belt loop is not fitted directly to the sheath, but instead to a hanger which is then bolted onto the sheath.
