Jerry Busse said about Paul's Hatchet: "If you're going to compare it to a full sized hatchet or kukri. . . it's gonna be begging for some leverage...."
and
"Now if your were to strap it to a Louisville Slugger, you could deliver some serious horsepower to the head, which would welcome the beating with open arms."
How could I resist?
I don't have a baseball bat, but I did get a hold of a 2O inch by one inch wood dowel and 20 feet of 3mm woven nylon cord, to experience how my knives would perform when leveraged to the extreme.
The first task was to securely fasten a knife to the dowel. It was much easier than I expected. The Busse knife handles are well suited to the task. The front guard, rear guard, and three tubular rivets make for a total of five holes to run my line through to lock the knife to the wood securely, while the front finger groove and the mid-handle swell make for three narrowed areas to prevent cord slippage. The flatness of the micarta slabs helps keep the handle flush with the wood, and their checkered texture also helps keep the cord from slipping. I simply ran my cord through the handles and around the handles and dowel as tightly as I could a few dozen times. That was it.
I tried out my Paul's Hatchet, my Steel Heart, and my Battle Mistress, as polearms. The results were impressive. I didn't do any careful chopping comparisons, but it was clear that there were dramatic performance improvements. I'd estimate that the performance was improved somewhere in the range of several hundred percent, compared to using the knives without a pole attached.
Now I'm wondering about how smaller blades would perform when attached to a sufficiently large club. It's already clear that my Paul's Hatchet will chop (a lot) better when attached to a stick than my Battle Mistress will when used without a stick. How well might my Satin Jack perform? Could a Pepper Shaker be used as a serious chopper? I'll know after further experiments.
I'm thinking that this greatly extends the potential uses of the smaller knives. In a pinch, they could be made into usable choppers, while still having the delicate whittling control and fine slicing advantages of smaller knives. You can find a suitable club pretty easily in most woodland situations. All you need besides that is a fraction of an ounce of cord. It is easy enough to find a rod and securely attach a knife that I think this is a reliable survival-skill technique.
You all need to go try this. It is both useful and seriously fun.
When I have the time, the materials, and the inclination, I will try to do some careful comparions of the performance of various knives when used with attached clubs to when used without attached clubs. I might also compare the performance increases of different weights and lengths of clubs.
Stay tuned.
--Mike
and
How could I resist?
Stay tuned.
--Mike
