Polish to satin.
Jonny D
Hello folks wondering what's the best way to change a finger print magnet high polish finish to a satin to help with smudges on blades like vg10 any help is appreciated, thanks!
On VG10, some wet/dry sandpaper (silicon carbide or aluminum oxide) in the 320-800 grit range will leave varying degrees of a satin finish. 320-grit, or sometimes even 220, will emulate a lot of factory satin finishes. Wrapping a piece of sandpaper around a rubber eraser makes a decent sanding 'block' which more evenly distributes pressure (makes a more even finish) and will conform to contours of the blade more easily.
You could also rub them down with a ScotchBrite pad, such as the green ones commonly found at the grocery store for kitchen/bath/sink cleaning duty. It'll work a bit more slowly than the wet/dry sandpaper, on hardened cutlery steels.
If using the sandpaper, you might start with a higher grit (maybe 600) and see what that looks like. It's better than starting too low and then having the too-coarse scratches left to clean up, if you don't like it that coarse.
David
The scotch brite pads work especially well and are more safe imo, as they go slower and won't remove a lot of material at all. You'll have to resharpen after using them, though
