Thank you VERY much!!!!!Basic idea is to sand at increasingly higher grit levels and then eventually use a full-sized buffer/buffing wheel with some polishing compound for final polishing.
A few tips:
1) Don’t move up in grit size too fast. Off the top of my head, a progression might look something like 220, 320, 400, 600, 800, 1000, 1500.
If you jump directly from 220 to 800 it’ll take MUCH longer to get the 220 scratches out.
2) Change the direction of work between grits to show your old scratches. In other words - say you sand tip to butt in 220 grit. When you move to 400 grit you should sand from spine to edge (perpendicular to the original direction) so you can tell when you’ve sanded enough. Then back to tip - butt sanding when you move to 600.
3) Make/use a sanding block
4) Understand that using a buffer on a knife can literally be fatal. Learn how to use a buffer safely before you turn it on.
5) Watch some YouTube videos on the subject.
Good luck!
