Cheap and fast way is with Mother's Mag wheel polish (Walmart, Target, Auto Zone, etc.) and a rag. Or use Flitz if you are one of those upper crust guys.
Always a good idea to sand in a linear direction, and alternate direction for each grit by 90°.
David, I also am in the process of polishing up some scratched bolsters, so let me ask about that. Is it less effective to do both directions while at each grit level, and then repeat at the next grit level, and so on? What I mean is to do a complete series in one direction, and then while staying with the same grit, alternate by 90 degrees and do a like series?
I've also had pretty good luck doing this kind of polishing with the Micro Mesh pads.
Andrew
My meaning was to imply one direction per grit, which is how I've done it. But, there's certainly no harm in doing passes in both directions with each grit, in the name of thoroughness. I think I'd still make a 90° switch in direction, in transitioning from the last pass of the previous grit, to the first pass of the next grit, to ensure the previous grit's scratch pattern is completely cleaned up. That's the bottom line, and if whatever you're doing is accomplishing that, then I see no worries.![]()
Thanks man! Haha, thorough explanation. I figured sandpaper with fine grit but I figured I would ask so I didn't destroy something unnecessarily.
