polishing speed
I am curious about the speed anyone uses for polishing blades, i have both 1725 rpm, 1/2hp, and 3450 rpm 1 hp. what do you use???
RPM doesn't make any difference the surface speed of the buff is what is measured(RPM X Buff diameter in ft.).
Critical buffing speed for steel is 5000 plus Feet per minute. Too slow and you get a hazy finish, there is no such thing as too fast. I often run at 10 000 feet per minute on large objects.
george
www.tichbourneknives.com
sales@tichbourneknives.com
When I first saw your title I laughed, because I coined a phrase a while back regarding projects I would be working on, when I set them aside to do something else, I would say they were being Air Polished, which occurs as air flows across the object and that can take a good while to get a nice smooth finish.
So speed for the air polishing is determined by how wide the window is left open and the wind velocity outside....
sorry but I couldn't help myself, I'm sure a lot of folks here have projects set aside that are currently undergoing the Air Polishing stage right now.....
Buffing also has a major element in what compound you use, on wood and leather I use the 1200 grit white compound from Texas Knifemakers as it does a fine job. Just take extreme care as the wheel has a mind of it's own and can throw a blade pretty quick if you aren't careful!
G2
"The Road to Hell is Paved with Good Intentions!"
Take the time to read your Bible Now, don't be left behind...
G2 LeatherWorks
[This message has been edited by Gary W. Graley (edited 03-29-2000).]
