Since there have been quite a few questions about removing scratches, I thought I'd pass along a polishing tip that Sal Glesser first posted on the Spyderco Forum. I forget whether the question pertained to removing scratches on blades or metal handles, but Sal mentioned that Spyderco uses Scotch-Brite so I decided to give it a try.
Since I don't have a bench-type belt sander, I went in search of hand pads and found two types in the local Home Depot. Although specific grits are not stated, Scotch-Brite 7447 (maroon) is marked as "very fine" and Scotch-Brite 7448 (gray) is marked as "ultra fine".
My first test subject was an old Puma Bowie that was also my first quality knife. It had been badly scratched from both years of hard use and some less than careful sharpening. In addition, I had it bead blasted about 15 years ago in my first attempt to improve its appearance. [I know, I know.
Please don't yell. I still feel badly about it.]
Anyway, rather than using the pads by hand, I used double-sided tape to attach them to an old cutting board to both protect my fingers and ensure more even pressure on the blade. The contraption was then held stationary while I moved the blade.
I started with a maroon Scotch-Brite pad and, after a few hours of on again/off again effort, wound up with a very nice satin finish. I then moved on to a gray Scotch-Brite pad and eventually achieved a near mirror finish. The remnants of a couple of the deeper scratches are still visible, but you really have to look for them.
The next knife to get this treatment was an aluminum-handled Spyderco Police that I had bought used. The blade was pristine but the handle was badly scratched from bouncing around in the previous owner's glove compartment. After a minimal amount of effort, the maroon pad had removed all of the surface and most of the deeper scratches, leaving a nice brushed aluminum appearance. I moved on to a gray pad and soon had the satin finish of a new knife. (Like the Puma, the remnants of a few deeper scratches are visible, but you really have to look for them.)
I haven't tried it on a khukuri yet, but I'm sure I'll like the results when I do.
Cheers,
--+Brian+--
Cheers,
--+Brian+--
