In an earlier thread I posted my desire to fabricate a missing pommel cap for a horn handled M43. With everything that has been going on the last couple of days, I've failed to post my pathetic attempt but I figure now is a good of a time for a laugh as any.....even at my expense.....
This certainly won't be too graphic (just picking on ya' Dan) but it is painful!! Started with the aluminium blank cut a little bigger than actual size. Found out that the little 2-3lb weights your wife uses for aerobics works pretty good as a form and with the plastic coating on the weight....it protects the blank
I haven't told her about her involvment yet, so we'll keep that to ourselves. Hit my finger several times during this process.
Made an initial mistake by drilling a hole in place for one of the tang rivets while the blank was still flat.....which mean't by the time I started curving the blank to fit the handle's arch, the hole was off by 2-4mm. Probably hit finger again around this point as well.
By the time I got a decent line up on the rivets, I had to address the issue of the handles arch from side to side as well as back to front. More hammering, more hitting of fingers & thumb. Hopefully, someone is getting a laugh out of this.......anyhow, finally got the blank to the shape & arch I wanted. Now I just need to deal with fabricating it out of a clean blank....stilling thinking of the cold rolled steel and figuring out how to do away with the hammer marks....thinking about a belt grinder with some fine grit?
Must go....fingrer hruts :grumpy:
Oh, Dan you were right.....I really appreciate what those guys do at HI.....and they don't even have a Lowe's down the street from them!!
