Originally posted by TimWieneke
Poplar is a great, easy cutting trim wood for your house, but I doubt it has the strength you want for a knife handle.
Tim
I respectfully disagree, Tim. I've made large bowls out of poplar with very thin walls less than 1/4 inch. They are all holding up just fine. With the curvature of the sides of some of my bowls, the grains themselves spread out over 3/4" between them! That makes for a very unique look.
I have also used poplar on knife handles that I have vacuum-stabilized with minwax wood hardener, and despite the "plastic" feel to them, they are quite hard and durable. Think about this: What is G-10 or Micarta? Nothing but paper, fiberglass, or cloth. Add the resin and you have a very durable product.
I've used Poplar in many different things, and its grain patterning has its merits and should not be dismissed as a poor choice of handle materials just because in its original state it is soft.
Oh and if any of you decide to experiment with poplar, I have a couple words of advice.
1. Be absolutely SURE its dry and seasoned well before you stabilize. Poplar is one wood that really suffers from warpage.
2. Keep whatever blades or instruments you use for working the wood very sharp, and SHEAR the wood - not just scrape it away. The shearing action produces a much better finish and you'll have less clean up, and way less fuzziness to the grain.
