Pork Belly Skinner Question...
I've got a few questions....
1) Is the handle profile the same is the AD or New MS?
2) Is the whole blade CNC'd, or ground first and then the groves CNC'd?
Thanks
Luke
Thanks
Luke
i dont know specifically, since this is a question of protocol jerry or someone from busse can only answer, buuuuut.... im pretty sure that
its the same as the active duty handle
and the entire blade is cnc'd. similarly to how the entire blade of the satin jack is cnc'ed, except on the pork belly skinner the larger grooves are larger then the small ones seen on the sj. on the portion of the pbs you'll probably see the same small ridge lines like you see on the sj
