I am here again to start yet another thread on generators. This is getting on my nerves now. Last month I bought a new Yamaha EF-2600 generator that is supposed to be a regular one not an inverter type. I wanted a regular one because the inverter type are not compatible with standard battery chargers.
One of the main tasks is for the generator to run the chargers so that I can use the batteries more and the generator less around camp.
The Yamaha seemed like a dream over my older super reliable Honda EZ-2500. The Yamaha has a larger fuel tank elliminating the need to refuel late at night, and it is much quieter too, but this is where it all ends.
I plugged in the chargers and.....
then:thumbdn: , then
and:grumpy: !!!!!!!!
Nothing for output but a few milli amps, pretty poor for 10 amp chargers. One is a reliable old Schummacher, and a regular Canadian tire 10 amp.
I set the Schummacher to 50 amp boost and managed to squeeze out 10 amps and brought the batteries back up. Not good though as I risk over charging as it is not regulated. Not good for the charger as it is mean't to run only 20 seconds at this setting, not several hours. But as the output is so low anyways the unit didn't barely warm up.
Came home and called the dealership. They are conducting some tests now and I hope they come up with a sollution.
It appears that the problem is the output wave form of the electricity from the generator. It is not quite the same as regular edison from the electricity company. Why would Yamaha do this? My Honda was fine and so was the cheap coleman generator I bought for $199 from Sams club many years ago.
I spoke to a couple of charger companies Xantrex and another, and the tech guy told me to expect this problem due to poor wave form output from these portable generators. They told me to go larger on the charger, saying that a 35 Amp charger should provide 15 on the generator. Another tech said to run space heaters on the generator while charging, so that when the generator runs under a heavier load its output is cleaner. Sounds like rubbish to me. Any ideas?
