I've asked here once
about water filters.
Since that time, I've done some researches.
First no
filter (ceramic or fiber-glass) will get rid of viruses. In some areas this is a minor problem, in some others it would require you treat any filtered water using chemicals (this doesn't make filtering completly useless, as removing particles helps chemical treatment a lot).
A few hints:
Treating pollution requires an activated charcoal.
Treating viruses requires some sort of chemical treatment. This is generally done (when offered) by iodine matrix (which leaves very little if any chemicals in water so can be used pretty extensively)
Ceramic may get some invisible cracks if dropped, which can substancially reduce filter's efficiency.
In the end I bought a Hiker which was available and not too expensive (and because viruses are not a major problem where I plan to use it). Many people highly speak of
pre-mac filters which are endorsed by the London School of Hygiene and Tropical Medicine. I've tried one once. Pretty ergonomic but flow is quite slow.
Katadyn pills come in three kinds:
1) Micropur classic: Silver ions: these are adapted for water
storage but you can't rely on them for initial treatment. No taste.
2) Micropur forte: these are silver ions plus chlorine. This means they are supposed to treat and then allow storage. Treatment is chlorine, with all chlorine limitations,
including swimming pool water taste.
3) I've seen some express treatment pills for emergency situation once in a shop these are supposed to treat recommended water volume within 15 minutes. I don't know what chemical they use. Might simply be concentrated chlorine. Costed about 3 times M. Forte price. Might not be suitable for extensive use.
