- Dec 24, 2020
Hey all, I'm brand new to knife making and just finished my first knife with 5160 then subsequently destroyed it. Directly after grinding off the scale from heat treat I noticed a crack in the edge that went up about a half inch towards the spine so I decided to just put a working edge on it and see if I could learn from its failure. Low and behold it snapped after being batonned through some oak logs. So what I'm wanting is some advice on how to avoid having my blade crack during the heat treat.
My intent was to make a pretty robust all around camp knife so I made it out of 1/4 material. Its blade is about 7.5 inches long and 2 inches wide. Its a full flat grind.
I did an edge quench because I want it to take a pretty good impact because I baton my knives from time to time to make firewood. I used an oxy acetylene torch to heat the edge past magnetic and I felt like it was a pretty even heat. I didn't bother flipping the knife over while heating because I felt that the heat was bleeding through pretty well but looking back this may have been the root of my problem. I quenched in about 1 quart of AAA oil heated to 200 degrees but then it had to be walked down 2 flights of stairs since the oven is on the top floor and I quench in the basement. I dipped about 2/3 of the blade in the oil and let cool for about 10 seconds then i sandwiched between 1/4 plates of steel and clamped. After it cooled to being just warm to the touch I brought it out to look at it. It had a slight warp to a small portion of the edge so ill be leaving the edge thicker on the next one but other than that it looked good so I set it down on the table of my grinder and that is when I heard the "ping". Anyway, I tempered at 450 for 4 hours and I achieved good hardness and toughness other than the crack.
So after that lengthy explanation my overall questions are:
1. Where do you think I went wrong and had that crack develop? Should I have heated both sides of the blade and that differential heating caused stress? Or is it something to do with my sandwiching method or did just setting it on the grinder table really do it?
2. Does an edge quench make sense in this role and do you have any advice on my heat treating method that I should do differently? Should the whole blade be heated then only the edge quenched or should the edge be heated and the whole blade quenched?
I've read as much information on heat treating 5160 as I could find and specifically edge quenching 5160 but there are so many opinions out there so I figured I would make my own thread with the specifics.
