Well , that s the way how I end up with ...........plunge less knifeBring your plunge line all the way back to take out all the goof, and duplicate on the other side? I'm guessing that would look odd. No way to add material and start over, so only thing left is to try and blend it and make it look intentional.
I can t help you with this , but for future I recommended you to use this jig to avoid accidents like this one .While I was on the belt sander putting in my plunge lines I slipped a little and caused a problem. is there any way to fix this without thinning my knife?View attachment 974666
Thank you for your time and potential help.
Diamond file? Daimond burr? I don't have a small wheel that is small enough for a choil on most knives. How do you cut the choil after HT? (or are you just saying add the choil after you establish the basic plunge lines, not after you finish grind them?) I have always just used the file guide as mentioned above.For the next one:
One reason to add the choil after the plunge is your present situation.
Actually, there is a way (imho)....No way to add material and start over...
Actually, there is a way (imho).Find very skilled tig welder and ask him to add material where You need it. Regrind plunge line. Then You have to repeat heat treating all over including annealing.
This is 67 hrc blade .I use cheap diamond burr for Dremel , they cut choil easy ....Diamond file? Daimond burr? I don't have a small wheel that is small enough for a choil on most knives. How do you cut the choil after HT? (or are you just saying add the choil after you establish the basic plunge lines, not after you finish grind them?) I have always just used the file guide as mentioned above.
Skilled welder knows how to fix it to welding table. Worked piece remain fixed to table until it is completely cooled. This ensure it will stay straight.... I figured it would warp the thing too badly to be worth saving...
