From what I remember, the difference between the pro and the glass stones is the binder and the glass backplate. When the pro was exported from Japan, depending on the climate and humidity a stone could arrive broken or with fractures. The Shapton pro stones generally are brittle, but still hard compared to a Naniwa SS. The smaller grids have the problem, that inbetween the big particles you have enough space to soak much more water than the finer stones. Surface tension of the water prevents it from flowing into smaller cavities, so normally the higher grid stones dry out faster.
The drying process can be a hazard too: if you live in hot arid climate zones (Arizona etc.) heat can dry out the top surface faster than the still soaked inner areas. This can lead to drying cracks and in the end lead to a broken stone
. To much air flow and direct sunlight are equally hazardous. Never soak any shapton too long, this can solve the binder an lead to a permanent weak spot, even when dryied out :grumpy: . Never use other fluids than water, no oil, no solvents, no soap, no chemicals. :thumbdn:
Shapton adressed the problem with a commercial rework: they glued the stones to a glass backplate, which prevents broken stones at delivery. This too prevents the underside of the stone from soaking up any water, so a crack completely throughout the stone is very rare without mechanical accident. I have no idea, to what extent they changed the actual recipe for the binder, they seem to have a different choice of gridsize, but still, people with the "too quick" drying problem claim their stone devellops small cracks in the surface.
People in temperate climate zones often use the Kuromaku series, which to my knowledge is the japanese original to the first pro version for export purposes. These stones have little problems, if you handle them properly. A big problem is that no matter what stone you buy, usually the instruction paper for all known hazards to the stone is in japanese. So even if you belong to those few who read instruction manuals, it makes no difference since most people still cannot read japanese...
