Cliff a long careful soaking in Naval Jelly might do the trick as well. I think if you coated it well and then wrapped in some sort of Saran Wrap or similar to help keep it from drying out and evaporating it might help do the trick.cliff355 said:My mower is a little big for that process, but I have a '92 Winchester given to me as a relic some time ago which is rusted shut. Unfortunately it also appears to be loaded and I have been trying to figure out a way to loosen that thing up and get the round out.
bismark77 said:In my experience electrolysis does NOT leave patina on a piece of metal. The process is actually removing a thin layer of metal (and the corrosion attached to it), and it ultimately leaves a bright, shiny surface. Yes, you can carefully remove corrosion using this technique and salvage some of the origional patina, but I would not try it with anything that is particularly valuable.
You also end up with an unbelievable volume of toxic biproducts using electrolysis--but it's very cool.
bismark77 said:http://www.flickr.com/photos/59116229@N00/sets/654334/
This is my first attempt at posting photos, so any help or advice is welcomed.
