Yes, but it is best to only re-heat small areas on a completed sheath to make the knife fit better. Re-heaing the area on the sheath where it locks on the hilt of the knife is common and can give you tighter or looser retention(whichever is desired). It is best done with a heat gun appying heat for a short time until the Kydex is pliable and then, while wearing gloves, apply pressure until it cools to the shape that you want! !If the area you need to reform is very small and you do not want to distort the area around the part you are working on, cover the outer areas with a rag/foil or somehing to block the heat!
