Post your converted or modified knife pics
sting7777
Inspired by an attempt last year to do this to a BM 750 (it worked but there were machining marks beneath the beadblast finish) and by the modified 630 in another post yesterday...
I have never been a fan of beadblasted Titanium finishes - so using Micro-mesh wet sandpaper and starting with 150 and moving all the way to 1200, my Sebenza now has a very smooth and comfortable feel to it and no longer gets scuffed or marked up at the slightest touch. The edges also get more highly polished giving it a pocket worn feel. I love it. :D
these are fairly large pics
Small Regular Sebenza with polished scales - open
Small Regular Sebenza with polished scales - closed front
Small Regular Sebenza with polished scales - closed back
Post YOUR modified knife pics!
I took a dremel and did a slow grind to get all the lazer marks off the hilt and tang, I left the lock part of the tang alone.
nice work on the sebbie handles. CRK's factory blast is a bit rough, I'd say - wish they went with higher grit glass bead / ceramic blasting, instead of the 80 grit aluoxide blast.
where do you get the micromesh paper?
eBay is where I found mine. I bought a kit that went from 100MX to 1200MX
G'day,
I didn't like the stonewashed blade on my small sebenza so I polished the hollow grind to a dull sheen with 180, 400, and 800 grit wet-and-dry. To add to the thickness and make it fit my hand better I added Australian Silky Oak scales. I don't use the clip so the scales cover the whole obverse side as well as the front.
Greg
Nice work!
Customizing knives can be an addicting, expensive and fun niche hobby within a hobby.
Here are a few I've done, several more can be seen at my web page.
A while back I took sandpaper to my 710HS to remove the BT2 coating. I didn't remove all of it because I got to the following look and stopped because I really liked the sortof 'antique', rough look. I did the same thing to the pocket clip, and have been wanting to do something in regards to the scales, but don't really yet know what that will be.
