im aware that using power grinders may affect your temper. is it possible to use a power grinder lightly and not affect temper? is the temper only affected if the steel begins to change color and can it be affected with out any visible signs?
if i run the grinder on a low rpm and just tap on an off the blade with the grinder, grinding in small increments... will the heat build instantly and then dissipate immediately, with me unable to feel the heat immediately after i remove the grinder from the steel?
