- Jul 22, 2014
I have had several power hammer questions and thought I'd just list them
-what are the advantages of a air hammer over a mechanical hammer(like a little giant)
-what are the advantages of a Japanese type hammer(with the belt holding the hammer head) verse something like a air hammer?
-what are some die changing systems that people have come up with for the homemade hammers?
-how do you heat treat a 4140 steel die? what RC do you want them?
-on the Japanese style hammers(like Murray Carters for lack of a better example) do the metal "C" looking thing that holds the hammer with straps does it flex at all? or does do the straps do most of the work?
-what height do you prefer the bottom die to be at?(Murray Carter has his at about belt high but little giants have them lower)
-could you work out a 2" ball bearing with a 35LB hammer?
-lets say IF I could us a 35LB hand hammer for hand forging on my anvil(my arm nor my anvil could take that) and I had a power hammer that was 35LB would they be able to move metal at the same amount per blow?(assuming the surface area and everything was equal)
-what is the quietis power hammer design out there? the Japanese seem to be prettty quiet
-what's the maximum beets per minute a 50lb homemade hammer should be desiged to do?
I'm just thinking through posibilitys and other things for my own hammer build AnvilFire.com has allot of good info to BTW
ANY questions you could answer would be great!!!!!
Thanks
Daniel
Thanks
Daniel
