White is usually 4-6 microns and green is 0.5-3 depending on where you get it. Green is finer than white.
That makes it sound like the green gives a finer finish then the white. I am not prepared to debate grit size. As I am sure you are aware, grit size isn't the only thing that determines scratch pastern and finish results. Maybe the grit in the white compound is bigger then the green but the white is softer or flatter then the grit in the white compound?
Many factors affect the resulting finish other then grit size like the hardness of the polishing media, how it breaks down, the carrier it is in, material it is applied to, force used, material being sharpened or polished, the speed at which it passes, etc. CrO's sizes and results are pretty well documented but, where did you get the grit size on the white? I don't see where they list it. Also, there is usually a range of grit size in a specified grit and the range or average size affects how coarse of fine the results of buffing with at are. There are two different white compounds for different finishes anyway.
I don't know the grit size and don't really care for practical purposes except that it might be interesting. I am more concerned with and referring to the results one gives vs. the other. I think anyone trying to decide what sequence to use them in would be too.
The result is the white leaves the finer finish when compared with the black or green. I get mine from Bark River but since this thread is referring to Pop's.
Here is what they say.
* 11B88 Black: fast cut
* 11B81 Green: medium cut and nice finish
* 525 White: light cut and nice finish
* HF1 White: mirror finish
I use the first three in the order they recommend and I think my results, power stropping on a belt grinder using a leather belt, are consistent with the labels. I use custom leather belts from SurgiSharp. I haven't used the white on a polishing wheel.
I haven't tried the Diamond spray yet but would like to.
