I've had my belt sander setup for several months now and have done a fair number of blades. I can, fairly easily, produce a polished (not mirror) edge by going from ~600 grit belt to green compound on smooth leather. This cleanly deburrs the blade and polishes it quite a bit in the process. These edges measure really impressively on the BESS tester. My last one, a ZDP-189 Delica, measured 90 to 105, which is really, really sharp.
But these edges have no bite. They aren't all that great at everyday tasks. I really do like an edge that's more like 220 to 400 grit, cleanly deburred without extra polish. In search of that edge, I've been following advice from someone on the BESS forums who recommends:
1. Grind with 180 grit belt to produce as small a burr as possible. (Mine tend to be larger than smaller, but not huge)
2. Wipe off the burr using medium (blue) ScotchBrite belt. This takes many passes and sometimes will not remove all of the burr. I often get a little bit of rounding doing this.
3. Finish with bare rough leather to remove the last little bits of burr.
4. (Optional) repeat 2 and 3 as required to get all of the burr.
I find that I end up with "welded on burr" or LOW (Line Of Weld) very often. I'll end up having to use increased angle or increased pressure, or both in step 2 above. This is time consuming and not super fun.
It occurs to me that there might be an in between way of doing this that might be faster and more reliable. Something like #1 (180 grit) followed by diamond compound on linen or leather. I know
Jason B.
likes 1 micron diamond for finishing. But is it good for deburring? The burr left over by a 180 grit belt is kinda big and nasty and requires a good bit of work.
Anyone have a favorite method for making a toothy edge with a belt sander that leaves you with a nice clean deburred edge?
Brian.
Brian.
