- Aug 13, 2002
This may have been posted before on here, but I just thought I'd post it again in case someone doesn't know about it cause it works GREAT! I have some shoulder problems so reaching on top of the mill for the drawbar and applying some force is not fun. And not only that but if you have to change the collets often for a particular project it can be very time consuming. I already had a shop air hose on top of the mill so I only had to buy a butterfly impact wrench. Cheap enough, 35$ on sale. :thumbup: I turned down the impact force to the minimum for this particular tool. I did not want to damage anything with too much force but, as Nathan the Machinist mentioned to me, if you do this just make sure that there is actually enough force being applied so that you don't get endmill slippage. For me the minimum setting is as hard as I use to manually tighten it.
Of course now I have to split the hose in 2 because I don't want to have to switch between the blowgun (which I use a lot for clearing chips) and the wrench but it's easy enough to do. And let me tell you it works sooooo good! I wish I had done it before. It's not hard to understand but even then here are a few pics.
