- Nov 2, 2006
OK I am retarted and missing a point somewhere but all I have read about the heat treat and temper I get the impression that while grinding prior to these processes you dont need to worry to terribly much about keeping the steel cool? because when tempering you heat it to X degrees to harden it, dont quote me on this but in the ballpark of critical temperature? am learning this in preperation but my point is I see posts about being careful not to overheat the steel while grinding. Am I correct to assume this is when the tempering is done and final finishing of the blade? because the way I see it if you can get a blade hot enough to ruin the steel prior to the temper it would be pretty impossible to handle it and grind.
Thanks in advanced
Thanks in advanced
