I'm finishing up my first (second really, but the first had too many mistakes to bother with ht) "from scratch" blade to get it ready for heat treating. I'll get a few more done before sending them, but want to completely finish this one first to learn as much as I can before I start messing up another piece of steel.
My question, after a lot of searching here, is what do folks do with the spine and tang edges? The common theme when discussing potential problems with heat treat is to avoid right angles and getting TOO thin anywhere. So do folks gently round over the spine and tang edges then grind them square again afterward? Or does the substantial thickness make it a non issue? The steel is 5/32 and the tip and edge are down to 1/16.
Also, and I should have thought of this before I drilled, what do folks do with exposed thong holes? Again, 5/32 ats34 steel, but if I countersink/taper the edge of the hole that will be visible. It's certainly a look, and I might actually go that route as a style, but am I likely to have problems if I don't? I could certainly bevel it and then just change the plan to have scales extend that far and use a tube if it's an issue.
Lastly, I've read various routines for how far people take the finish before heat treating, but little as to the reasoning. Since I'll have to refinish anyway, is there a real benefit to going beyond 220 grit belts first? Is this an issue that depends on the exact ht methods and steel used and other variables?
My apologies if all these questions are covered in a tutorial I missed somewhere, I did run into a few that my anti-virus screamed about and several dead links, so it's possible the info I need was there or I just missed it in my reading.
Remy
Remy
