I got a bunch of this stuff about two years ago.It is 420 SS ,which is OK for simple kitchen knives,but not great.I made about thirty kitchen and fillet knives and they were OK.It is no problem to fit the scales to the blade.Just drill the holes in the tang a bit over-sized,glue on one scale,drill the rivet hole a bit undersized,glue on the other scale,drill both with the correct size drill . I place another piece of the tapered stock (with a 1/2" rivet holes in it) under the handle when drilling the final assembly and it will compensate for the taper in the tang.
PLUS - It was fast and simple to make the knives.It is cheap.
MINUS - If you want a 420SS knife go to K-mart,that is what most $3.00 cutlery is made of.
I never got any more of this material.I got to agree with Mike on this - Learn to grind,then you can use good steel.
Stacy
