- Nov 24, 1999
I'm having steel problems here.
I started out buying O1 from a local machine tool supply. It was labeled flat ground, and was exactly what I wanted. Almost perfectly straight, uniform thickness and perfectly flat.
Then I decided to try 440C and ordered hot rolled steel. Obviously, that was a bad choice since at least half the stuff I make is folders. Some of it was actually pretty good, but most of it was really wavy. I used it up making kitchen knives.
Next I tried precision ground 440C. I don't know what to think. The face of the steel isn't really flat at all. They took a peice of hot rolled steel that was supposed to be .125 and ran a surface grinder over it. Only about 90% of the face is ground, and testing it with a micrometer I'm seeing a variance of about 5 thousandths between random spots. I haven't tried working with it yet, so maybe stuff will come out alright. I was expecting a cleaner peice than this when I paid twice the cost for precision ground.
They took off all the high spots, but the hot rolled peice I got with it is almost dead on at .13 anywhere I measure, and the ground stuff jumps all over. Is this what you usually get? I only got 2ft, and I've been really happy with this supplier for everything else. So I don't want to bad mouth them, or return the steel. I probably won't order any more steel from them if I can get better from somewhere else though.
Am I expecting too much?
