- Aug 25, 2003
Finally getting to work on the press I've had hydraulics for, for the last year. The first pic is of the press body, which is made of 6"X 2"X 3/8" square tube for the uprights and W6X 25 I beam from the crossovers. The second pic is the welding/drawing dye's and are low carbon steel
http://groups.msn.com/BladeBlacksmithing/shoebox.msnw?action=ShowPhoto&PhotoID=70
http://groups.msn.com/BladeBlacksmithing/shoebox.msnw?action=ShowPhoto&PhotoID=71
I was going to use the frame from a press that I got from my father in law, but as the cross piece is 2' I was concerned with the deflection of the steel so I decided to just make a frame for it. The uprights are 48" and the crossovers is 12", this steel was purchaced from work for around $100, the dyes were made from steel that I got from the scrap bins at work. On the areas that will take the pressure I welded it at work, as they have serious welding equipment, the only pressure piece that I welded at home was the lower mount for the hydraulic piston. At home I only have a 220V AC buzz box, and I really hate welding with AC, but when the machine is free it's for me
. At work I used flux core wire feeder at around 250 amps, at home I used 7018, 3/32" stick wire designed for AC. 18 series wire is usually DC, but using DC wire on and AC machine is a real pain in the A$$
I've built a table to set the press on which should put the dye around 40" high, the table will also carry the oil tank, pump, etc. The table will be mounted on wheels as everything in my garage/smithy has to be portable
As I see IG often I got the hydraulics that match his Big Bertha press, these parts are listed on Dan Gray's web page in his tutorial section.
I've still got to get the mount for the pump and the HYD lines for the press.
Hopefully I'll have this squiching steel in a couple of weeks
Larry T
Larry T
