I don't think pressure is the problem. More likely the angle of the knife edge does not match that of the sharpmaker and you are not actually sharpening out to the edge. This is a common problem with people new to the Sharpmaker.
I think the Sharpmaker does a dinkum job of maintaining an edge once that edge is at the same angle the Sharpmaker is. Getting the edge to that angle using a Sharpmaker can be a chore.
Do this:
Use a Sharpie to color the edges of the blade, then take a couple of swipes on the Sharpmaker and look at the edge under a hand lens. Wherever there is black, the edge is not hitting the sharpener. If there is black on the very edge, that means you are not sharpening there. Until you can take a couple of swipes and see no black on the very edge, you are still changing the edge angle rather than sharpening.
IF you are only changing the edge angle, you can either keep after it with the corner of the Sharpmaker rods or use a coarse Benchstone. Either way, I would not try to progress beyond the corner of the medium Sharpmaker rod until I passed the Sharpie test.
